Author Topic: Ok now what - lost ALL electrical  (Read 8894 times)
Offline ChallengerHK
Re: Ok now what - lost ALL electrical
« Reply #30 on: October 30, 2015 - 06:53:07 AM »
I'm no electrician, but I've had similar results when the main fusible link failed.
- Han Solo, Star Wars
Offline ShelbyDogg
« Reply #31 on: October 30, 2015 - 06:54:51 AM »
Yes, if the disconnect failed, or the battery feed wire connection at the bulkhead came loose(red wire), that is the same scenario that I had, which is running a charging system without a battery.   When you said all of your lights blew out, I knew your battery connection failed.
Do the alternator charge stud to battery or starter relay wire. Bypass your 2 bulkhead male/female spade connectors (the big black wire, the big red wire) by drilling right through and running a #10 through the hole. Get rid of the amp gauge.
If you run a disconnect switch, make sure it kills your alternator too and not just disconnect the + battery post.
Offline BS CUDA
« Reply #32 on: October 30, 2015 - 10:11:06 PM »
Done done and done. Just hoping I found the culprit - both the red and black wire showed signs of heat as well as where they connected to the ammeter. 2nd failed disconnect in very short time - quite confident they were not the cause but a result.
