Author Topic: Installing a Hemi is a really tight fit!  (Read 4995 times)
« on: May 23, 2015 - 10:41:48 PM »
I wanted to start a topic on lowering the chassis onto the Hemi engine already mounted on the K member.
Dropping the body onto the Engine/trans assembly.
The clearances to drop the body over the engine on each side for a Hemi and clearing the apron shock tower is really really close. I'm talking less than a quarter inch on each side.
While lowering the body, it can easily end up hitting on either the driver side, (power steering box side) or the P/S side rocker hitting the shock tower.
It happened to me today and scraped a little paint off on the bulge that protrudes out.
Not a big deal, I'll get it blended in later.
I just wonder how in the hell did the factory put these behemoths in without hitting any paint surfaces?
The only thing I can come with to wiggle these in under such tight clearances is by tilting the engine assembly on the passenger side.
If you are experienced in getting these in, and do it like it's the size of a slant 6, I'm all ears listening.
Re: Installing a Hemi is a really tight fit!
« Reply #1 on: May 23, 2015 - 10:54:21 PM »
I have done 1/2 dozen this way , no issues , aftermarket covers often do not fit , 2 people 1 adjusting while the other is lowering , , lifting one side of the engine does help too , piece of cardboard or duct tape . .....
Offline roadman5312
« Reply #2 on: May 24, 2015 - 07:16:14 AM »
 :popcorn:    :popcorn:
Offline cordodge
« Reply #3 on: May 24, 2015 - 07:54:07 AM »
I should have my alterkation in a few weeks and then i will be in the same situation, i have the tall after market covers and doing some measuring im 1-1/2 too wide. I would rather install it without removing the cover/covers so i am going to build a cart that will allow me to tilt the alterkation with motor installed up on one side or i could possibly just tilt the motor up on one motor mount and keep the k-frame level , and also i was going to use two engine hoists one on each side of the car so i can tilt the car the opposite way just enough to clear the covers then level everything out and connect the k-frame. I know removing the covers would be easy but it is all sealed up nice and i did not want to disturb it. not saying it will work but i am going to give it go anyway and if not then i guess i will take the passenger side cover off.
good idea on the cardoard.
what do you guy's think?
Thx Bruce
1970 challenger 95% done
1969 roadrunner in progress
1969 D-100 13,000 mile truck
1969 L-700 tilt cab in progress
2007  Dodge Ram 4x4
2017 hyundia Santa fe ultimate
1977 VERY UNDERSTANDING WIFE !! 😇
« Reply #4 on: May 24, 2015 - 09:00:02 AM »
A timely post for me, going to help install a 426 into a buddy's Cuda real soon. Great info!  :2thumbs:
Offline anlauto
« Reply #5 on: May 24, 2015 - 10:21:42 AM »
I use two large pieces of cardboard as a shoe horn :2thumbs:
Offline Racer57
« Reply #6 on: May 25, 2015 - 09:51:38 AM »
Instead of using cardboard which will tear, use bathroom shower vinyl wall covering panels.
Offline ToxicWolf
« Reply #7 on: May 25, 2015 - 11:26:24 AM »
Really great here too.  Tim just shipped ours out today.   :bigsmile:
Offline roadman5312
« Reply #8 on: May 25, 2015 - 11:27:59 AM »
                   :woohoo:   :cooldancing:   :ylsuper:   :clapping:   :bananasmi
