Author Topic: is my starter bad  (Read 845 times)
Offline cudasteve72
is my starter bad
« on: May 24, 2015 - 02:42:29 PM »
I have a new battery new cables pretty much new everything electrical via painless wiring.  The starter is also new but was not wired tight upon initial install some sparking took place. All connections are tight.  When i turn it over it wines and clicks like it would if the battery were dead.  Any thoughts.  Am I on track thinking starter?
Help
1972 Cuda Custom 70 clone  416 stroker 481/531 hp/
2006 Grand Cherokee SRT8 (daily)
1970 Challenger convertible 340 (Dad's)
1967 Dart gt slant six all original 40,000 miles driver but needs restoration (Brother's)
2011 Jeep Grand Cherokee (wife's)
Offline crash340
Re: is my starter bad
« Reply #1 on: May 24, 2015 - 04:09:33 PM »
I had the same issue, turned out the plug on the Park/Neutral switch was loose on the auto trans. you can bypas test it at the starter relay by earthing the G terminal to a good earth and test crank it, the Trans switch simply provieds the earth for the starter relay to work, bad earth poor starter solenoid function.
Greg
73 Cuda
Brisbane, Australia
