Author Topic: B Body to E Body pinion angle  (Read 880 times)
Offline crash340
« on: May 24, 2015 - 04:26:37 PM »
does anyone know if the B Body housing has a different pinion angle to the E body housing? I swapped housings the other day and it looks like I need to put a 2-3* shim in to raise the pinion of the B Body housing compared to what it was with the original E Body.
Greg
73 Cuda
Brisbane, Australia
Offline mopar jack
Re: B Body to E Body pinion angle
« Reply #1 on: May 24, 2015 - 05:50:31 PM »
The angle is different but know how much. I bought a b- body housing from Dr. Diff to install in my cuda and he sells the shims to correct the angle. You could call him and see what you need.
Offline crash340
« Reply #2 on: May 24, 2015 - 10:33:20 PM »
Thanks MJ
I have got some 2* shims coming, I measured it at 3*, best I could so settled for 2* for the meantime
Greg
73 Cuda
Brisbane, Australia
