Author Topic: 1970 K Frame Measurements  (Read 1398 times)
Offline 3D
« on: May 24, 2015 - 08:07:09 PM »
Is there anyway to confirm that my K member is not bent?
I have several to chose from but I would like to check it before I blast and power coat it.
Any input is welcome.
Thanks
Offline Bucks70RT
Re: 1970 K Frame Measurements
« Reply #1 on: May 27, 2015 - 12:52:46 PM »
Only experience I have with bent K is where the strut rod goes through it. K can be bent backward if wheel hits a curb or something hard. Which pushes the control arm backwards.
Offline Falbz
« Reply #2 on: May 27, 2015 - 02:44:54 PM »
I'd say just try and bolt it up to check if it's twisted and frame bolts don't line up :clueless:
« Reply #3 on: May 27, 2015 - 03:00:49 PM »
Its not k frame specific, but there are some references to check in this thread: http://www.cuda-challenger.com/cc/index.php?topic=106373.msg1044413#msg1044413
Offline jimynick
« Reply #4 on: May 27, 2015 - 10:53:27 PM »
Lay it on a decently flat floor and see how the arms measure to the floor, then I'd cross measure to the corners and check for consistency. Bolting it in will also tell a tale, as mentioned. The MkI eyeball is your friend as well.  :cheers:
Offline 3D
« Reply #5 on: May 28, 2015 - 01:59:01 PM »
MkI ???
I be sand blasting it this weekend so I'll be checking it out, ill also be re-welding everything.
Offline soundcontrol
« Reply #6 on: May 28, 2015 - 03:39:36 PM »
I just welded mine and got worried that it got bent from heat, but I testfitted it to the car and it fits perfect. If you need any measurements I can do it since it's on my stand right now.
/ Ken
topic=108917.new#new
Offline jimynick
« Reply #7 on: May 28, 2015 - 09:46:20 PM »
"MkI" was old Brit shorthand for "Mark one" or the first, original variant of something- in this case, your own, original, eyeball. In other words, look at it- carefully and critically, as the first order of business. Good luck  :cheers:
