Author Topic: heater fan wiring gone bad  (Read 594 times)
Offline dakota
« on: May 25, 2015 - 06:39:35 AM »
For those of you that may be considering keeping your original wiring harnesses:  check them carefully before making your decision!
Up until this weekend, I've been thinking I would keep the original wiring harnesses in my car.  Not any more.  With the engine out, I was able to get "up close and personal" with the firewall.   When I removed a retaining clip in the middle of the firewall, I found a burn spot on the paint behind one of the wiring runs.   During the search for the cause of the burn, I came across a break in the feed to the heater blower (not sure this was the cause of the burn).  After removing the blower for a closer look, the insulation on both the power supply and ground wires were found to be cracked at the strain relief on the fan housing - definitely not a good thing.   Between these wiring failures,  the wire from the fusible link to the starter relay breaking off when I moved it, and several hacked in taps to the harness inside the car, I think it's time for this stuff to leave.
Offline dakota
Re: heater fan wiring gone bad
« Reply #1 on: May 25, 2015 - 07:02:58 AM »
Based on other posts here, I just ordered a set of M&H harnesses through Year One.  Year One has a 30% off sale (promo code MEM15) that ends today.  The discount definitely took some of the financial sting out of the order.
