Author Topic: Spark Plugs for 318  (Read 3236 times)
Offline Fred
Spark Plugs for 318
« on: May 25, 2015 - 09:40:43 AM »
May be subjective, but what is a good plug and wires for a 71 318 bored .30, 70 340 4bbl intake, Holley 600, very mild grind on stock cam, and stock electronic points?
It currently has Split Fire SF6E from 20 years ago.
Offline cudabob496
Re: Spark Plugs for 318
« Reply #1 on: May 25, 2015 - 01:19:06 PM »
I use 8mm MSD wires, and NGK plugs
2011 Kawasaki Z1000
Offline Fred
« Reply #2 on: May 25, 2015 - 01:38:38 PM »
Thanks cudabob!
Offline aris_unlimited
  • Project in full swing
« Reply #3 on: May 25, 2015 - 06:20:57 PM »
I too just put NGK plugs in mine. Hoping they'll last longer than the Champions I had in before them. Those champions were massively fouled up with heavy deposits on them after less than 5k miles.
« Last Edit: May 26, 2015 - 12:57:10 PM by aris_unlimited »
Cuda is gone :(
74 satellite, daily driver/project now
Offline cudabob496
« Reply #4 on: May 25, 2015 - 06:31:32 PM »
I too just put NGK plugs in mine. Hopi g they'll last longer than the Champions I had in before them. Those champions were massively fouled up with heavy deposits on them after less than 5k miles.
oil leakage or running rich?  bad power valve?
2011 Kawasaki Z1000
« Reply #5 on: May 25, 2015 - 10:17:58 PM »
I would use RN12YC  Champs , in my experience the NGK will foul far faster than the Champion is everyhting is right
« Reply #6 on: May 26, 2015 - 01:00:28 PM »
Does have a small oil leak, but it's external and doesn't even lose a quart between 3k mile oil changes. Not sure what you mean about power valve, unless you're referring head valves. But they'd have to be bad on every cylinder, because all the spark plugs looked bad.
Cuda is gone :(
Offline Fred
« Reply #7 on: May 26, 2015 - 01:35:14 PM »
Thanks CP.  To be clear, you are suggesting this as an option for my engine I mentioned above?
Offline brasil
« Reply #8 on: May 26, 2015 - 03:00:10 PM »
Autolite 65  in my 340 cui
Autolite 85 in the BBs
Greetings Juergen
Offline cudabob496
« Last Edit: May 26, 2015 - 03:48:49 PM by cudabob496 »
2011 Kawasaki Z1000
« Reply #10 on: May 26, 2015 - 07:39:33 PM »
https://www.youtube.com/watch?6v=WfjkeC3dPSI
Is that a problem only on holleys? I still use the original 2 barrel carburetor. Pretry sure it's a carter if I'm remembering correctly.
https://www.youtube.com/watch?v=5_lgTTkXJDM
Cuda is gone :(
Offline cudabob496
2011 Kawasaki Z1000
« Reply #12 on: May 26, 2015 - 08:06:02 PM »
Yes
Offline Fred
« Reply #13 on: May 28, 2015 - 09:37:15 AM »
Thanks!   :thumbsup:
