Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Electrical
(Moderator:
Chryco Psycho
How to remove bulkhead connectors?
« previous
next »
Print
Pages: [
1
Author
Topic: How to remove bulkhead connectors? (Read 739 times)
annularnos
Jr. Member
on:
May 25, 2015 - 01:24:36 PM »
Is there some trick to unplugging the connectors on the engine side of the firewall bulkhead? I assumed that the two large white connectors would pull right out. Can't seem to remove them and I figured I'd ask before I break them.
Logged
anlauto
Permanent Resident
I'm Alan G...I'm a Mopar Addict
Re: How to remove bulkhead connectors?
Reply #1 on:
May 25, 2015 - 01:39:11 PM »
Squeeze the ends in and wiggle them off
Logged
annularnos
Jr. Member
Reply #2 on:
May 25, 2015 - 01:42:30 PM »
That's what I attempted to do....they don't want to move at all.
Logged
Bullitt-
Permanent Resident
Better Things To Come Member Since 2/16/06
Reply #3 on:
May 25, 2015 - 01:47:16 PM »
I've had to wedge a flat blade screwdriver between connectors to separate them on occasion
Logged
Wade 73 Rallye 340..'77 Millennium Falcon...13 R/T Classic
Huntsville, AL
TelisSE440
Sr. Member
Reply #4 on:
May 25, 2015 - 02:14:40 PM »
Use some WD-40 (with the battery disconnected) and spray to the connectors inside the wires. Let it settle for a while, then spray it again and then push the ends and pull them continuously from the sides (left and right), it'll come off..
Logged
annularnos
Jr. Member
Reply #5 on:
May 25, 2015 - 02:25:55 PM »
Got it. Thanks for the support. I just didn't want to break it and wanted to be sure that it was supposed to come apart that way. I used a large pair of channel locks to simultaneously squeeze the ends in while I wiggled the connector off. Hard to believe it took that much coaxing. Thanks again.
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
Electrical
(Moderator:
Chryco Psycho
