Author Topic: Aftermarket volt gauge. Batt / Acc male spade fuse box spot  (Read 2705 times)
Offline Bluemonster71RT
In my 71 Challenger, there are 2 spots on the bottom of the interior fuse box that have a male spade connector. One says batt and the other is Acc.  I'm trying to install my Autometer volt gauge and was wondering if I can connect to the batt gauge? Is it switched? Or the Acc one? Thank you.
1971 Challenger RT 383 4spd
Offline roadman5312
Re: Aftermarket volt gauge. Batt / Acc male spade fuse box spot
« Reply #1 on: May 25, 2015 - 01:37:24 PM »
Acc is switched , batt hot all the time.
« Reply #2 on: May 25, 2015 - 01:53:53 PM »
Good deal!!! :bigsmile: Thank you.
Offline roadman5312
« Reply #3 on: May 25, 2015 - 03:10:46 PM »
And it's good to remember that most acc feeds go dead when your cranking the motor. When the key is in run or acc they are hot.
« Reply #4 on: May 25, 2015 - 03:17:06 PM »
That makes sense. Any idea what the BATT one would have been used for? Diagnosis for techs back it the day?
Offline roadman5312
« Reply #5 on: May 25, 2015 - 03:34:59 PM »
                 Not really sure, I know all fuse boxs from all the auto makers had them. Possible diagnosis while working under dash. Also could have been used for options that could be added by the dealer. It's where I plugged in for the power to my Mini 8 Track back in the day so me and my main squeeze could listen to tunes with the key off   :2thumbs:
Offline blown motor
« Reply #6 on: May 25, 2015 - 04:01:18 PM »
If you use the Batt terminal MAKE SURE you use an inline fuse. The PO of my car didn't and I nearly burned my car up.
« Reply #7 on: May 25, 2015 - 04:09:44 PM »
The ACC one is fine without a fuse?
Offline roadman5312
« Reply #8 on: May 25, 2015 - 04:24:33 PM »
               I believe it's fused. Test with test light, pull fuses one at a time, see if light goes off. I believe the batt terminal is only protected by the fuseable link on the battery cable, takes quite a short to blow it.
« Reply #9 on: May 25, 2015 - 06:17:15 PM »
Instead of that spade connector on the fuse box I would recommend using the molded accessory connectors behind the gauges. They are part of the dash harness and are made for accessory add ons.
Don't remember off hand if it is the red or yellow that is switched. Yellow i think. You will end up with a cleaner install.
« Reply #10 on: May 25, 2015 - 08:18:48 PM »
This is what I did so that would of been a less than optimal route. Thank you though.
