Author Topic: New Alternator recommendations (with Vintage Air)  (Read 5728 times)
Offline soundcontrol
Re: New Alternator recommendations (with Vintage Air)
« Reply #15 on: June 03, 2015 - 01:30:47 PM »
We're in the (slow) process of putting a Vintage Air system onto a big block (compressor on top). The instructions show only one groove needed.  Also the system came with its own alternator bracket, but I couldn't see any reason to not use the stock brackets.
Hmm..  interesting, I found pictures that used 2 belts, (small block, like mine) and my compressor has 2 grooves also, I assumed I needed 2.
Gotta investigate more. Can you change the pulley on an alternator from 1 to 2 groove later? (Found a 1 groove alternator for sale).
Edit: after some more research: Looks like I need a 2 groove after all, Install instructions pict for a 340.
« Last Edit: June 03, 2015 - 01:46:18 PM by soundcontrol »
/ Ken
topic=108917.new#new
Offline tommyg29
« Reply #16 on: June 03, 2015 - 03:55:57 PM »
The lower picture two post up is exactly my setup. Modern sanden compressor only has and only needs one belt.
The last pic looks like a oem type compressor setup to me.
« Last Edit: June 03, 2015 - 03:58:19 PM by tommyg29 »
« Reply #17 on: June 03, 2015 - 04:04:26 PM »
Picture is from Vintage air's install instructions for small block. Mine is a Sanden, bought it last year and it has 2 grooves.
/ Ken
Offline tommyg29
« Reply #18 on: June 03, 2015 - 05:42:02 PM »
Learned something today. Ive never seen one with 2
Offline FY1Cuda
« Reply #19 on: June 03, 2015 - 08:31:10 PM »
You could call Vintage Air and ask them if you really need two belts or if one would do it.  The other consideration is if you have enough grooves and the right offsets on the water pump and crank pulleys.  I had to get another water pump pulley from Bouchillon to make it all work out.
« Reply #20 on: June 04, 2015 - 04:08:18 AM »
I mailed them, waiting for a reply. My crank pulley has 3 grooves so I assume one will work with waterpump/PS pump and the other 2 will line up with compressor/alternator, hopefully...
/ Ken
