Author Topic: Getting Incorrect undercarriage color using DP40/DP90 mixture  (Read 1205 times)
Offline manycj
I finally got my undercarriage of my 1970 Challenger (Hamtramck built) in first primer this weekend.  Since it was not the final priming/ painting (I will be going for the factory original look), I thought I would try to using a mixture of primer that has been floating around on the forums as something that reflects the factory correct color. I think it originated from an old Mopar Muscle article. I first tried 2:1 of DP40LF : DP90LF as the first coat and found it to be way to dark.  The next coat I tried 4:1 of DP40LF : DP90LF which is what you see in the picture here. The actual color is darker and more blueish than what you see here(For reference contrast the rest of the car is in DP40).  There is no way that that either mixture of DP40LF/DP90LF) is correct either.  Maybe the formulas I've been seeing are for the non-LF versions of the primer. I didn't really want  to, but I might try the undercarriage paint from Resto Rick. What do you think? -Chris
Re: Getting Incorrect undercarriage color using DP40/DP90 mixture
« Reply #1 on: May 26, 2015 - 02:17:00 PM »
RestoRick's paint should hold up better then just primer.  That's probably what I'm going to do on my Dart.
Offline 750-h2
« Reply #2 on: May 26, 2015 - 02:50:55 PM »
To me the color is good, however it should be shinier. I think most are using enamel paint and adding some flattening agent.
Offline anlauto
« Reply #3 on: May 26, 2015 - 03:23:12 PM »
Yea..you want to use paint not primer :2cents:
Offline js29no
« Reply #4 on: May 26, 2015 - 06:40:21 PM »
 :iagree: allen is right! dp40lf & dp90lf is a ppg product, the L-f is for lead free. i don't think thay make dp40 or dp90 any more. the good news is you have i be leave a week to top coat it with out having to sand it.
