Author Topic: Hot rodding the 3.6 Pentastar  (Read 21659 times)
Offline myduster360
Re: Hot rodding the 3.6 Pentastar
« Reply #15 on: May 05, 2016 - 11:58:03 AM »
I didn't know if anyone's still considering this swap but I'm doing it in my 72 Dart. Saving +300lb off the front end off the car over a Hemi is a plus and is just begging for a couple EcoBoost turbos.
What transmission to use was a major stumbling block initially but Quicktime now has bellhousing to mate a Tremec T5.( pn RM-4070). Just thought that info could be useful.
Offline YellowThumper
  • I left the snow for this?
« Reply #16 on: May 05, 2016 - 01:02:13 PM »
Interesting enough and different.
Should start a build thread for it...
Offline GreenFish
« Reply #17 on: May 06, 2016 - 08:12:58 AM »
That would be really cool. Keep good notes. Lots of folks will be interested. I think there is easily 400HP to be had out of that engine. Its so light weight the performance benefits will be awesome.
Offline moparman82
  • MOPAR or No car
  • Livin' the dream
« Reply #18 on: May 06, 2016 - 02:13:05 PM »
Ecoboost turbos?  U going to hit a salvage yard to pull turbos off a f-150?
Scott in Omaha
2015 crew cab Hemi ram SOLD
2019 Ram Laramie
2016 Tahoe LTZ SOLD
1976 Ramcharger 383 4spd SOLD
2016 Audi
24 mopars past and 2 present
Offline myduster360
« Reply #19 on: May 07, 2016 - 01:46:25 PM »
Wrangler guys have been putting on superchargers and turbos for a while and are getting 370hp at the wheels through their hp suckling 4wd drivetrain.
I towed the shell of my dart 400mile through the hills of  Mo with my 13 Caravan 3.6 and got 18.5mpg..lol so even though my original plan was a 5.7 hemi, the size, weight, hp and redicoulsly flat torque curve of the 3.6l won me over.
I Have a 30k mile 3.6l out of a  2013 wrangler on it way.the wrangler seemed to have the best intake and oil pan setup for the swap.
That QuickTime bellhousing to mate a T5 is on its way too. I haven't worked out the details of the clutch/flywheel.
Offline myduster360
« Reply #20 on: May 07, 2016 - 01:52:16 PM »
There are lots of take off turbos from f150 guys upgradin and the orientation of the left and right 3.5 ecoboost  turboss seemed to lend themselves to the single exhaust port of the 3.6l,,,,,but that's really phase2. Getting the engine in and up and running as is, will be phase 1
Offline GreenFish
« Reply #21 on: May 09, 2016 - 07:23:08 AM »
 :2thumbs: Hell yeah dude, that's awesome. Yeah, my Town and Country has the 3.6 and its a nice running motor. Can't wait to see what you get into with this. What engine management do you plan to go with?
Offline GreenFish
« Reply #22 on: May 09, 2016 - 08:01:35 AM »
Definitely want a RWD engine.  I believe there are differences in a FWD and an the RWD jeep engines. Do the trucks have the 3.6 also?
Offline GreenFish
« Reply #23 on: May 10, 2016 - 08:32:28 AM »
Found this today. I knew about this SC but didnt know the "claimed" HP. Edelbrock claims 427HP with a bolt on SC. Not too shabby for a light weight v6
http://www.fourwheeler.com/news/427hp-for-3-6l-pentastar-jk-wrangler-with-edelbrocks-e-force-supercharger/
Offline myduster360
« Reply #24 on: May 10, 2016 - 02:13:58 PM »
I'm a Diablo CMR tuner and also have HpTuners which can both tune the 3.6's PCM, so I want to stick to the factory PCM. Besides needing it for the VVT, the flex fuel option will be nice when using E85 with the turbos. Getting around the security maybe the most challenging part of this project. Since the Jeep gets its speed input from its ABS module, using the electronic throttle is probably not an option but we'll see. I know the guys from Diablo that helped that GasMonkey Dart run its Hellcat hemi, so I'll see what they say.
I know another guy in CA putting a 3.6L + Edelbrock SC+T5 in his 69 Valiant. Im riding his coat tails a bit. He got another prominent Hemi tuner to flash a special PCM and super secret black box to bypass the PCM security. So that's another option.
From my research the Ram 1500 3.6l uses the same intake as Jeep but much different rear sump oil pan. Every other FWD 3.6l uses s different intake and "front" sump oil pan,
Offline GreenFish
« Reply #25 on: May 10, 2016 - 04:30:44 PM »
Just fyi, Megasquirt will do VVT, and flex fuel. I like the stock PCM option though probably the safest way to go in this case.  Ill be watching as I really want to put one in a 65 Barracuda
Offline myduster360
« Reply #26 on: May 12, 2016 - 01:55:44 PM »
. The Stock PCM is light years ahead of an MS, so it would be a last ditched, best worst option
« Last Edit: May 12, 2016 - 05:01:18 PM by myduster360 »
Offline GreenFish
« Reply #27 on: May 14, 2016 - 06:03:01 PM »
Cool, I can't wait find out more. What do you use to interface with the computer?
Offline myduster360
« Reply #28 on: May 14, 2016 - 06:12:34 PM »
I tune with Diablo CMR or HpTuners
Offline GreenFish
« Reply #29 on: May 15, 2016 - 09:38:47 AM »
Oh wow, I just googled Diablo CMR, I had no idea that was around. So thats what they were using on GassMonkey? Cool  :thumbsup:
