I'm sure this has come up before, but here goes. New master cylinder, new brake lines, original proportioning valve and metering block. Didn't bench bleed the MC (when I've done that before, the bench becomes a toxic super-fund site). Pumping the brakes with a rear bleeder open did nothing. Leaving it overnight with a rear bleeder open did nothing. Borrowed a brake bleeder suction device today and tried it on the both rear wheels. The compressor was getting hot after twenty minutes, but brake fluid wasn't getting back to the wheels. Tried the suction bleeder on the front left--nothing. When I pump the brakes, I kinda think the fluid in the front smaller reservoir raises, but then settles down to the original level. Pretty sure the booster rod is set the right length (just missing the piston).
Any thoughts?
