Author Topic: For those with stealth heads  (Read 3740 times)
« on: May 28, 2015 - 02:27:07 PM »
What spark plug should I use? Any recommendations out there?
Re: For those with stealth heads
« Reply #1 on: May 28, 2015 - 07:33:34 PM »
WHat does it suggest on the 440 Source site , I think it is a RC or RV plug champion plug
Offline mrwfp
« Reply #2 on: May 28, 2015 - 07:49:02 PM »
Source 440 recommended the extended length Champion RC12YC plugs when I bought their heads last year.  They have to be the extended length and not the regular ones.  Source 440 sells them and are the best place to get them.
« Last Edit: May 28, 2015 - 08:02:41 PM by mrwfp »
« Reply #3 on: May 28, 2015 - 10:30:35 PM »
That's just it. They say they sell the plugs, but not what they are.
:2thumbs:
Thanks mrwfp
Offline ireland383
« Reply #4 on: May 29, 2015 - 11:33:02 AM »
I run the RC12YC plugs in my stealths or autolite 3924 both were fine got them at wallyworld for cheap no need to use the source for them. :2cents:
1971 Plymouth Barracuda
Offline dave73chally
« Reply #5 on: May 29, 2015 - 11:56:15 AM »
Good to know for the future  :thumbsup:
73 Challenger
Offline HP_Cuda
  • Mopar or No Car!
« Reply #6 on: May 29, 2015 - 01:53:12 PM »
Yup RC12YC plugs straight from 440source, although depending on your header selection it may be actually easier to install because they are longer.
 :2thumbs:
« Reply #7 on: May 29, 2015 - 03:00:50 PM »
 :thumbsup:
Thanks for the feedback guys. I want to install them saturday so I need to buy them locally
 :cheers:
Offline mrwfp
« Reply #8 on: May 29, 2015 - 07:57:46 PM »
Just make sure that you get the correct extended length plugs.  I bought a spare set of plugs from Amazon because they were cheaper but they were not the extended length plugs and would not work.  The standard plugs do not go deep enough into the heads to fire correctly.
Offline 1 Wild R/T
« Reply #9 on: May 30, 2015 - 01:47:12 AM »
Want a better plug?
NGK 1273 BCPR5E-11 V-Power Plug
« Reply #10 on: May 30, 2015 - 10:30:02 AM »
Want a better plug?
Why do you think it is better?
My only experience with NGK is with my mercury outboard and found it ran better when I switched to equivalent Champions. I only switched because I had a hard time finding the mercury recommended NGK small engine plugs locally.
Offline 1 Wild R/T
« Reply #11 on: May 30, 2015 - 11:46:12 AM »
Because I've dealt with Chumpions that foul easily for to many years... I refuse to buy their junk...
« Reply #12 on: May 30, 2015 - 11:46:49 AM »
 NGK have never worked well for me either
