Author Topic: Thermostat Housing Swivel type  (Read 1021 times)
Offline 74BlueFish
« on: May 28, 2015 - 08:34:16 PM »
I bought this swivel thermostat housing from summit and don't know what thermostat to buy.  The one I bought is the same size as the housing so the O ring will seal only one the t stat   not the water pump housing.
Anything smaller than the o ring size will fall into the water pump
What am I missing.   will the swivel fit on a Mopar aluminum water pump housing?
Any help will be appreciated.
Dan
Dan
Offline drewcrane
Re: Thermostat Housing Swivel type
« Reply #1 on: May 28, 2015 - 08:39:48 PM »
I tried one and never got it to seal I hope yo have better luck ;)
Offline 74BlueFish
« Reply #2 on: May 29, 2015 - 08:37:19 AM »
what thermostat did you use?
The one I have appears too big.   If I install it  will seal on the O ring on the top of the thermostat but the bottom of the stat will be on the water pump with no seal.  Seems wrong to have to put a gasket there.
Dan
« Reply #3 on: June 09, 2015 - 12:35:54 PM »
its for Chevy.  I used what looks to be the same one. I made up a new base and welded it  to suit my new rad.
« Last Edit: June 10, 2015 - 07:09:10 AM by brads70 »
Offline edl94
  • She Cuda
« Reply #4 on: June 09, 2015 - 11:43:11 PM »
 I bought the same housing a couple of years ago hoping it would work. It looks good sitting on the shelf.
