Author Topic: Carb and intake suggestion  (Read 793 times)
Offline battrm
« on: May 30, 2015 - 09:05:04 AM »
I have a stock 1970 340 with j heads and I need a carb.  What carb and intake would yall
Suggest.   Car has a manual transmission.  I was thinking since I need a carb why not change
The stock intake.  I am not sure of what cfm the motor needs.  Thanks
Offline rUNCHARGER
Re: Carb and intake suggestion
« Reply #1 on: May 30, 2015 - 10:41:20 AM »
Stock intake is pretty good actually and hard to improve on. Personally I would put a 650 AVS on it but there are lots of good choices out there. Just don't put an AFB on it.
Sheldon
« Reply #2 on: May 30, 2015 - 11:51:56 AM »
 The factory intake is one of the best , not worth $300 to go sideways IMO
 Carbs you want 2 x the CI so 650-700 CFM , My preference is Proform or QuickFuel or Holley HP series
 EFI rules if you can afford it
Offline cudabob496
« Reply #3 on: May 31, 2015 - 03:06:17 AM »
I keep hearing about EFI nightmares.
they got the bugs worked out??
2011 Kawasaki Z1000
Offline brasil
« Reply #4 on: May 31, 2015 - 06:12:40 AM »
get a Thermoquad
does your engine have the OEM cast intake... with the spread bore design ? If so....   one more reason to pick up a "new TQ "
Greetings Juergen
BTW  my 340  runs great with the TQ   better than   EDE AFB  or AVS...
