How much oil can leak from a distributor?
Author Topic: How much oil can leak from a distributor?  (Read 880 times)
Offline 74 challenge
« on: May 30, 2015 - 01:00:21 PM »
I have been chasing an oil leak for quite some time.
I threw on a new intake gasket thinking that was the issue and a new distributor gasket but I'm still leaking just as much as before the repair. I have mine ripped appart again and I'm just not convinced it's the intake gasket.
I replaced the rear main seal last year thinking that was the issue. But the oil is leaking from the area where the sending unit , disto and intake meet.
About 2 table spoons of oil hit the floor after I shut it off and while driving a drip hits the long tube exhaust manifold.
Can this be caused by a crappy disto o ring? Is there a gasket for the sending unit? Or just some Teflon? Can that much oil leak from a distributor?
1-8-4-3-6-5-7-2
Re: How much oil can leak from a distributor?
« Reply #1 on: May 30, 2015 - 01:34:26 PM »
My bet is it is the sending unit causing the problem , I chased a similar problem years ago & it was a split in the fitting to the oil gauge .
 It could be just the threads requiring teflon tape or liquid sealer or it could be coming through the sending unit requiring a new one .
« Reply #2 on: May 30, 2015 - 01:40:41 PM »
I'll throw this curve ball in there. I have a mechanical guage so it was just a adapter attached to a friction fitting attached to a plastic line. I'm thinking this is the issue since there is no sending unit.
1-8-4-3-6-5-7-2
Offline jhaag
« Reply #3 on: May 30, 2015 - 02:39:46 PM »
what do you mean, "friction fitting"? it should be a feral type connection. Lose the plastic hose and replace it with copper tubing. much safer. reseal the fitting in the block with Teflon. completely clean the area with brake cleaner, and then look for your leak. you can also put dye in your oil to help find the leak. doubt it is coming from the distributor.
love 70 Challengers
Offline 73_Cuda_4_Me
« Reply #4 on: May 30, 2015 - 03:10:49 PM »
 :2cents: The brass ferrule has nicked the plastic tubing for the gauge... had same thing happen... local hardware store has new compression fittings, and I was able to redo the seal... the copper tubing is best, but I still have the plastic tubing, and no new leaks for two years...
1973 Plymouth Cuda BS23H3B567783
R11 V6X EN2
M21 M25 M31 M88 N41 N42
V1X U B41 C56 G37 J54
JY9 A6X9 0 703 501616
E55 D34 BS23 H3B 567783
Offline cudabob496
« Reply #5 on: May 30, 2015 - 03:15:40 PM »
my vote, top, back of engine
or valve cover gaskets
« Last Edit: May 30, 2015 - 05:14:33 PM by cudabob496 »
2011 Kawasaki Z1000
« Reply #6 on: May 30, 2015 - 04:54:40 PM »
I am getting rid of the mechanical guage as a whole and going to an autometer electric one. Cleaned out the whole thre some Teflon on the new one and snugged it back in.
I'm also re doing the o ring and distributor I guess if it leaks next year I can take it all appart again and re-do the intake gasket.
1-8-4-3-6-5-7-2
Offline brasil
« Reply #7 on: May 31, 2015 - 06:15:17 AM »
..mechanical oil pressure gauge ?  I always use the steelflex hoses from autometer    I don´t thrust those  Plastic lines....
Greetings Juergen
