Author Topic: ball joint removal  (Read 1205 times)
Offline MoparMatt383
  • Member as of March 2004
ball joint removal
« on: May 18, 2005 - 04:40:58 PM »
As you know I am rebuilding my front end.  I was able to remove the tie rods by using a fork, but that was as far as I got.  Next it said to remove the upper ball joints from the A arm and the spindle, but I could not get them to break loose.  I took off the cotter pin and nut so that isnt holding it back, but I am still getting no movement.  Is there something I am missing?  Any help would be greatly appreciated.
Matt
Too many projects and nothing gets done.
Offline hemi71
Re: ball joint removal
« Reply #1 on: May 18, 2005 - 05:37:19 PM »
Are you trying to get the spindle loose from the a-arm? I'm assuming thats what you are doing. Thats just an interference fit...just give it a good couple of GOOD wacks and it will come apart. Now the upper ball joint is threaded into the upper control arm...you need the trick socket to get it out of the control arm. DONT try to drive it out with a hammer..you'll need a new control arm if you do as you'll screw up the threads.
« Reply #2 on: May 19, 2005 - 09:10:14 AM »
Thanks 71
Can you get a ball joint socket at any parts store or is this something that is specific to mopar and I would have to go through a dealer?  Also which ball joint should be taken out first?  Upper or Lower?
Matt
Offline hemi71
« Reply #3 on: May 19, 2005 - 01:53:50 PM »
A good tool place should have the sockets. I've had mine for years, so i just might be showing my age here!  LOL
« Reply #4 on: May 20, 2005 - 01:52:40 AM »
I don`t think it reallymatter which joint you separate first , , I usually split the lower first using the T bar to help then split the upper using the weight of the spindle to help
« Last Edit: May 20, 2005 - 10:26:58 PM by Chryco Psycho »
Offline hemi71
« Reply #5 on: May 20, 2005 - 06:53:21 PM »
« Reply #6 on: May 22, 2005 - 08:18:34 PM »
Thanks 71, but I was able to borrow one from a friend that works in pep boys.  I tell you guys I wish I would have done this before I got my car painted.
Matt
