Author Topic: Convertor balance weight removal  (Read 2127 times)
Offline bandt
« on: May 30, 2015 - 10:04:04 PM »
Hi Guys,
I went from an externally balanced rotating assembly to a internal one. My current torque convertor has a small balance weight. I think all I have to do is knock that weight off. Correct?
I already have the proper flex plate to go with the new crank.
Thanks,
brian
Re: Convertor balance weight removal
« Reply #1 on: May 30, 2015 - 10:14:45 PM »
Yup knock the weight off
Offline bandt
« Reply #2 on: May 30, 2015 - 10:33:31 PM »
Thanks Neil,
Can I use any ATF?
« Reply #3 on: May 31, 2015 - 04:08:07 AM »
new trans ?
 if so you could use F type , ATF will work too there are some newer formulas such as ATF+4 that are for new vehicles but any normal atf will work
Offline bandt
« Reply #4 on: May 31, 2015 - 09:51:31 AM »
No same ole 727.
Has been leaking since I got the car. Dumping the fluid. Im going to replace the pump seal.
Thanks, I thought I could use any kind.
Offline ShelbyDogg
« Reply #5 on: June 09, 2015 - 05:44:27 PM »
Change the shifter shaft seal first, that might be the one leaking
Offline bandt
« Reply #6 on: June 10, 2015 - 08:38:07 PM »
Thanks,
Yeah I replaced the shaft seal at one point.
Offline mopar jack
« Reply #7 on: June 10, 2015 - 10:12:58 PM »
external balance weights are on the flat side of the converter near the drain plug. Your pic shows a weight that was probably used to zero balance the converter and not the crank shaft.
Offline Katfish
  • 70 Challenger
« Reply #8 on: June 11, 2015 - 06:48:17 AM »
I was thinking the same..........
« Reply #9 on: June 11, 2015 - 07:58:12 AM »
I was thinking the same thing, but then again, maybe they put them in different spots in different years?
Bandt, do you have any on the front face of the converter?
Offline bandt
« Reply #10 on: September 04, 2015 - 11:00:14 AM »
Sorry just saw this.
There were no balance weights on the front or rear face of the convertor. The balance weight was on the side. As some people said it was to neutral balance so I didn't remove it and it has been fine.
Brian
