Author Topic: Rocker Shafts  (Read 675 times)
Rocker Shafts
« on: May 31, 2015 - 11:40:12 AM »
I didn't pay close enough attention when removing the originals to notice the orientation of the oil holes.
When the shaft is installed, are the oil holes offset towards the exhaust port side or the intake port side of the pedestals/
Re: Rocker Shafts
« Reply #1 on: May 31, 2015 - 11:47:11 PM »
intake
Re: Rocker Shafts
« Reply #2 on: June 01, 2015 - 07:12:37 AM »
Thanks CP. I found no clear answer searching the internet. People suggested up, down, inboard, outboard.  :sly:
Re: Rocker Shafts
« Reply #3 on: June 01, 2015 - 08:30:35 AM »
When the valve is open & the rocker is tipped this will put the oil hole in the center of the load on the rocker
