Hey guys,
I'm still trying to solve my popping/backfire problem from last year.
Here is that link -
http://www.cuda-challenger.com/cc/index.php?topic=100501.0I even swapped carbs.
So today I did a compression test and as I pulled each plug, I noticed 6 & 8 are nice, the others aren't lookin so good.
The tips on a couple of them seem white-ish.
I'm guessing 6 fowled plugs?
So what does that tell me?
I installed new plugs and wires last summer.
Running Holley 850 DP. Not sure of the guts.
AFR is around 14-ish at idle and 12 to 13 when peddle action.
I wrote the compression reading (cold crank) next to each plug. All with cranking 8 compression cycles during the test. Is this a clue to something?
Thank you in advance for your thoughts.
Tom
