Author Topic: What do these spark plugs tell you?  (Read 4538 times)
Offline CudamanTom
« on: May 31, 2015 - 07:00:29 PM »
Hey guys,
I'm still trying to solve my popping/backfire problem from last year.
Here is that link - http://www.cuda-challenger.com/cc/index.php?topic=100501.0
I even swapped carbs.
So today I did a compression test and as I pulled each plug, I noticed 6 & 8 are nice, the others aren't lookin so good.
The tips on a couple of them seem white-ish.
I'm guessing 6 fowled plugs?
So what does that tell me?
I installed new plugs and wires last summer.
Running Holley 850 DP. Not sure of the guts.
AFR is around 14-ish at idle and 12 to 13 when peddle action.
I wrote the compression reading (cold crank) next to each plug. All with cranking 8 compression cycles during the test. Is this a clue to something?
Thank you in advance for your thoughts.  :wave:
Tom
1971 Cuda 440-727 - (clone)
Because I like it fast!!!
Offline acudadude
Re: What do these spark plugs tell you?
« Reply #1 on: May 31, 2015 - 07:14:43 PM »
# 6 = lean condition or water entering cylinder ie coolant?
Offline mopar jack
« Reply #2 on: May 31, 2015 - 08:13:50 PM »
Read through the previous post and saw no mention of spark plug wires. I would check the routing and make sure number 6 and 8 aren't crossed. The number 6 plug is not burning and looks to clean. If the intake valve is not opening i.e. the cam lobe is flat there will be no fuel to burn. I doubt the cam is flat because  you will hear a lot of valve train noise and the push rod would be bent or not connected to the rocker and you probably would not have a good compression reading.
Offline jhaag
« Reply #3 on: May 31, 2015 - 11:01:24 PM »
I would agree that 6 and 8 are not firing. Others appear on the rich side. Compression test should have all cylinders within 10%. Looks close. Looks like an electrical issue to me.
love 70 Challengers
Offline hooD
  • detroit iron
  • Motor City Made Muscle
« Reply #4 on: June 01, 2015 - 01:50:09 AM »
Check the inside of your distributor cap for all the contacts being corrosion free.  How's the rotor looking?
-Larry
member since AUG 2007
southeastern michigan usa
1973 'CUDA 340
original owner
37,117 miles
Offline CudamanTom
« Reply #5 on: June 01, 2015 - 07:04:16 AM »
Some good thoughts here.
I will verify the wiring is in correct order and check the distributor cap & rotor.
I forgot to mention it's electronic ignition with a MSD 6A system.
« Reply #6 on: June 01, 2015 - 08:51:51 AM »
possible vacuum leak through the brake booster , too rich overall but 6&8 are lean , using a hotter plug might help
Offline dfrazz
  • 1970 Cuda - 1968 Charger
« Reply #7 on: June 01, 2015 - 09:01:48 AM »
Its pretty obvious when the wires are crossed as you should hear a significant miss or even a backfire.
Offline HP_Cuda
  • Mopar or No Car!
« Reply #8 on: June 01, 2015 - 12:03:13 PM »
Based on your AFR readings it would seem you have a electronic issue.
What kind of coil are you using with the MSD 6A box? And/or maybe a good time to replace plug wires.
Offline CudamanTom
« Reply #9 on: June 01, 2015 - 01:00:59 PM »
I'm using the MSD Blaster 2 coil. Also, I just replaced the wires last summer and probably have maybe 10 to 20 hours of total run time with the new wires and plugs.
Offline CudamanTom
« Reply #10 on: June 01, 2015 - 01:02:42 PM »
I do get random backfire/popping when starting out in 1st gear or reverse (under a load)
Offline CudamanTom
« Reply #11 on: June 01, 2015 - 01:03:25 PM »
I don't have a brake booster.
Offline HP_Cuda
  • Mopar or No Car!
« Reply #12 on: June 01, 2015 - 01:37:07 PM »
Tom
Is the Blaster 2 coil mounted horizontally or vertically?
B
Offline CudamanTom
« Reply #13 on: June 01, 2015 - 05:46:52 PM »
Tom
B
B,
I had it horizontal at first then read about it should be verticle (pointing up) so it's been verticle most of the time.
Offline CudamanTom
« Reply #14 on: June 01, 2015 - 07:28:05 PM »
Well Jack nailed it.
I verified the wiring and  :banghead: :bricks1: :pullinghair: :banghead: :bricks1: :pullinghair:
They were crossed. :walkaway:
So I feel like a total idiot for something so easy and I should have checked a long time ago. :banghead: :bricks1: :banghead: :bricks1: :banghead:
Funny thing, because it has a cam, I guess the lumpy idle seemed almost normal and I was surprised how well it did run with these two crossed. Which is why I assumed the wiring was correct and ran too good to be incorrect. At least in my mind it did.
So I still need to purchase new plugs and will report back here in a few days.
Thanks to everyone and your thoughts and inputs.  :wave:
I will keep this for future spark plug issues.
Tom
