Author Topic: check coil to see it works  (Read 9159 times)
Offline Kevin71
Re: check coil to see it works
« Reply #30 on: July 07, 2015 - 12:30:39 AM »
I'll give it a try.  Thanks
Offline Kevin71
« Reply #31 on: July 07, 2015 - 07:28:38 PM »
I realized I have a direct power line from the battery to the msd unit.  Wouldn't this provide a consistent voltage?
Offline Kevin71
« Reply #32 on: July 07, 2015 - 07:43:51 PM »
How do you know if voltage regulator is bad?
« Reply #33 on: July 07, 2015 - 08:29:09 PM »
Simple step by step here http://troubleshootmyvehicle.com/chrysler/3.9L-5.2L-5.9L/alternator-test-2
They don't mention the need for the regulator to have a good ground as well as + signal through the wiring, bad connections can create issues here as well
Offline Kevin71
« Reply #34 on: July 07, 2015 - 09:39:23 PM »
If I put the distributor in off by one notch would the car run and would it run bad.  I adjusted the timing with a light at 36 degrees all in at 3000 rpm.  The motor seemed to smooth out but then I let it sit over night and it's sputtering sounds like it's missing.  Confused.
« Reply #35 on: July 07, 2015 - 11:31:25 PM »
Nope 36-degrees is it no matter if the drive gear is off or not.   So it runs good one day then bad the next without any changes..
Could the choke not be opening completely early enough?
Offline Kevin71
« Reply #36 on: July 08, 2015 - 10:38:48 AM »
I will take a look at that, hopefully this afternoon
« Reply #37 on: July 09, 2015 - 11:45:27 AM »
MSD has 2 power leads , one is 12 ga from the batter the second is small 18 ga switched from the ballast resister connections it just closes the relay & shunts power from the battery when the key is on
Offline Kevin71
« Reply #38 on: July 09, 2015 - 03:06:12 PM »
So it could be the smaller one from the ballast resistor wires.
Offline dutch
« Reply #39 on: July 09, 2015 - 05:55:30 PM »
maybe a stupid question, but how are your sparkplugs doing after all start attempts and poor running...?
*** Bart ***
Offline Kevin71
« Reply #40 on: July 09, 2015 - 06:24:51 PM »
They were brand new when I started.  Better pull a couple and take a look.  They could have fouled by now.  I like where you are going with this.
Offline Kevin71
« Reply #41 on: July 11, 2015 - 06:18:39 PM »
Plugs were black and smelled of gas.  So I got a new set and thought I would replace them and check all the plug wires one more time as I replaced them.  Should I set the spark plug gap as .35 or higher.  MSD litature says it should be around .50 for 10.5:1  compression.  Mine is a 522 stroker with 10:1 compression.  Also how do I check the voltage at the small 18ga wire.  I am just looking for it to be 12 volts.  What about amps?
Offline Strawdawg
    • Vortex Buicks
« Reply #42 on: July 11, 2015 - 08:56:17 PM »
Think i already answered this but I usually set gaps to 0.045".
Measure the voltage with your meter. Don't worry about amperage
Sent from my LG-H810 using Tapatalk
