Author Topic: Power Steering Pump Rebuild  (Read 2262 times)
Offline CUDA JAS
  • vroooooom!
« on: June 01, 2015 - 01:45:06 PM »
Ok, so any tips to getting the reservoir off a Saginaw power steering pump?
I set out to rebuild mine today and I just can not get the damn thing apart!!!
74 'cuda 360/727
Just call me a gearhead!
Offline anlauto
Re: Power Steering Pump Rebuild
« Reply #1 on: June 01, 2015 - 01:48:33 PM »
It has what every Walrus wants.....A nice tight Seal.... :smilielol:
With the bolts out....it should just pull apart.. :2cents:
Got pictures ?
Offline HemiOrange70
« Reply #2 on: June 01, 2015 - 01:52:08 PM »
Offline CUDA JAS
  • vroooooom!
« Reply #3 on: June 02, 2015 - 08:35:15 PM »
Got pictures ?
Alan...that is so wrong man!!!   :smilielol:
Bolts...which bolts????
I'm kidding, yes I took the bolts out.  Sorry no pics.
I stopped and put it all back together after I started to bend the outside rim of the reservoir trying to separate it.  I did not want to destroy the thing.
This is the old style pump, not the newer triangular type pump.
So any tips before I try it again?
Jason
74 'cuda 360/727
« Reply #4 on: June 03, 2015 - 10:56:23 AM »
They can be difficult.  Make sure the fitting that the PS hose attaches to is removed.  It's not part of the reservoir...it's a separate piece.  Spray the perimeter of the reservoir with penetrating oil and let it sit and work down into the gap.  Just go easily.  You may bend it a little...I did.  You'll have to straighten it out once it's off.  Rebuilding the pump itself is gravy.
« Last Edit: June 03, 2015 - 07:13:27 PM by burdar »
Offline roadman5312
« Reply #5 on: June 03, 2015 - 03:53:09 PM »
Also when you take the fitting off that Burdar spoke of there may or may not be a valve and springs in there.
Offline CUDA JAS
  • vroooooom!
« Reply #6 on: June 05, 2015 - 05:39:27 PM »
Yep I removed that fitting (all the internals are there as well).
I am trying not to make the car undrivable for any length of time, so, I just put it all back together for now.  I my try it later in the summer if it looks like we will get a crappy week, so I can let it sit for a few days.
No big deal, its not leaking too bad at this point.
Jason
74 'cuda 360/727
