Author Topic: Rack and Pinion options and opinions  (Read 3296 times)
Offline GreenFish
« on: June 02, 2015 - 08:58:43 PM »
R&P, is it worth it over some of the steering boxes that are available now.
I am going to convert back to power steering from manual.  The borgeson box is about $750. Ill need a pump, brackets and hoses as well around $250.  and the Classic industries R&P is $1200 but it comes with a PS pump and bracket which puts it much closer in price.
How is the R&P? has anyone used it with stock K frame?
Offline moprr
Re: Rack and Pinion options and opinions
« Reply #1 on: June 02, 2015 - 09:45:53 PM »
The rack from classic industries looks like it's a unilsteer kit, if that's the case reviews are horrible.  I was considering that system till I read some reviews.
« Last Edit: June 02, 2015 - 09:49:43 PM by moprr »
Offline 1 Wild R/T
« Reply #2 on: June 03, 2015 - 12:05:10 AM »
I just looked & yes thats Unisteer.... Run....
« Reply #3 on: June 03, 2015 - 12:16:53 AM »
you will lose turning radius with most systems
Offline GreenFish
« Reply #4 on: June 03, 2015 - 07:18:05 AM »
Yep it is, I saw it on speedway motors as well for $999. Thats a shame, are there any other options?
« Reply #5 on: June 03, 2015 - 09:14:59 AM »
There are not any decent retrofit R&P units. You can make the R&P work well, but you have to swap in a suspension system designed to work within its intended range, ie Alterkation or Magnumforce. So then your steering swap costs $8000, but you get altered spring and shock rates along with revised geometry.
Offline GreenFish
« Reply #6 on: June 03, 2015 - 10:06:54 AM »
Thanks, i'm not looking to go full out coil over system. Ill stick with a nice steering box
« Reply #7 on: June 03, 2015 - 10:19:42 AM »
The factory steering system is actually very good , you can use Firm Feel or Steer & Gear steering boxes with far better feel along with offset bushing in the upper control arms etc & get a decent handling car
Offline Priesty
« Reply #8 on: June 03, 2015 - 08:00:35 PM »
Can't go past the Borgeson box imho.
Best mod I've made for driveability, feels just like modern steering with tighter ratio & easy fit up, if you use the Bergman steering coupler.
 :2cents:
Steve - 72  BS23  FY1  'Cuda.
Melbourne, Australia.
The term "Foolproof", seriously underestimates the ingenuity of fools.
CUDA Crop by steve, on Flickr
Offline GreenFish
« Reply #9 on: June 04, 2015 - 07:25:45 AM »
Thanks, I think the Borgeson box seems to be the way to go.
