Author Topic: Power Steering  (Read 552 times)
Offline dana60
Power Steering
« on: June 03, 2015 - 12:45:32 AM »
I have a 70 Barracuda that i am going to put power steering in. I have a power steering unit from a 68 B-Body that I am going to use. My question is, do I need to change out the pitman arm to make this work ? If so, where can I get a pitman arm that will work with an E-Body?  Is there anything else I need to make this work? Thanks everyone!   :wavingflag:
Offline tman
Re: Power Steering
« Reply #1 on: June 03, 2015 - 12:54:49 AM »
Offline GreenFish
Re: Power Steering
« Reply #2 on: June 03, 2015 - 07:47:37 AM »
Should be the same. I went from power to manual years back and kept the same pitman arm.
