Author Topic: Speedometer with no Cable required!  (Read 3115 times)
Offline cudabob496
2011 Kawasaki Z1000
Offline RCCDrew
Re: Speedometer with no Cable required!
« Reply #1 on: June 03, 2015 - 07:57:49 PM »
Does that just work all the time? No monthly fee or something? I'm not savvy to these newfangled parts!
Offline ToxicWolf
« Reply #2 on: June 03, 2015 - 08:23:02 PM »
The only time it doesn't work is in tunnels, etc. They block the GPS signal.  Always free after you buy it.  I had mine converted to GPS.
Offline Katfish
  • 70 Challenger
« Reply #3 on: June 03, 2015 - 09:04:41 PM »
I wonder where the GPS antenna needs to be mounted?
Offline dutch
« Reply #4 on: June 04, 2015 - 01:56:41 AM »
Speedhut gps speedo`s have been around for a while.  Works great, very accurate, not in tunnels though.  I had the antenna mounted in the centre of the dash, right against the windshield.  Worked fine.
*** Bart ***
Offline TelisSE440
« Reply #5 on: June 04, 2015 - 02:46:02 AM »
GPS offers very accurate speed, but too high tech stuff to install in these cars IMHO. Anyway, deosn't it have to search for satellites in the beginning? I mean starting your cars and taking off you won't have signal for a while. But hey, you need to warm up first...
Offline dutch
« Reply #6 on: June 04, 2015 - 05:47:28 AM »
speedhut has an extra feed wire to keep connection all the time, so on start up there`s immediate signal.
*** Bart ***
Offline HP_Cuda
  • Mopar or No Car!
« Reply #7 on: June 04, 2015 - 06:29:41 PM »
Usually they will try and find 2 or 3 synchro satellites before they begin to work.
Offline RCCDrew
« Reply #8 on: June 06, 2015 - 09:40:55 AM »
so your factory looking speedo is GPS? Who does that conversion?
Offline Mopar Thunder
« Reply #9 on: June 06, 2015 - 11:31:43 AM »
I have that GPS speedometer and it works great.  My 904 I am selling had the input area blocked so I bought one of these. The GPS antenna is located in the lower corner of the passenger side window.  Can't really see it.
Offline grimmey71
« Reply #10 on: June 07, 2015 - 06:53:12 AM »
I ran my speedhut gps sensor to my rear package tray, works great
Offline ToxicWolf
« Reply #11 on: June 07, 2015 - 12:41:16 PM »
Redline did it.   :bigsmile:
Offline Katfish
  • 70 Challenger
« Reply #12 on: June 07, 2015 - 05:04:11 PM »
I'd love to see a pic of the conversion.
I'm guessing it's now digital and not the needle now?
Offline roadman5312
« Reply #13 on: June 07, 2015 - 05:29:49 PM »
Digital odometer only, amp to volt meter. Cool grafics on tach.
Offline grimmey71
« Reply #14 on: June 08, 2015 - 09:55:01 AM »
 :wow:
If I only would've know about this, that looks great. Anymore info would be apprecietated
