Author Topic: Replacing the Key-in Switch  (Read 1274 times)
Offline spamtank
« on: June 05, 2015 - 12:38:47 PM »
Is it possible to replace only the Key-in switch in the steering column, or must the entire turn signal switch assembly be replaced?
What is the best re-pop source for the switch or entire assembly?
Thanks,
Rick
Rick, Manchester, NH
1970 SE 383 2V AT Challenger
1977 M882/W200 Power Wagon
2013 RT Plus 6M
Re: Replacing the Key-in Switch
« Reply #1 on: June 05, 2015 - 01:26:22 PM »
The turn signal switch, ignition switch and lock cylinder are all individual pieces that can be replaced separately.
Offline spamtank
« Reply #2 on: June 05, 2015 - 01:55:00 PM »
Thanks, I thought I saw a picture and description of it being part of the turn signal switch.  But that wouldn't make sense since it's part of the ignition switch harness.
2013 RT Plus 6M
« Reply #3 on: June 05, 2015 - 04:04:06 PM »
It depends which part you need , Rock auto should list the electrical switch usually made by Standard , they probably list the lock also if that is what you need , there is also the switch for key in ign warning which us also separate & I do not know if a repro part
Offline spamtank
« Reply #4 on: June 19, 2015 - 06:37:52 PM »
Just a quick follow-up.  I'm looking for the "key-in" switch.  I'll be looking for one at carlisle in a few weeks.
2013 RT Plus 6M
« Reply #5 on: June 19, 2015 - 07:28:16 PM »
I believe Rock Auto lists the lock under Standard parts
 US71L  $16
Offline spamtank
« Reply #6 on: June 19, 2015 - 08:08:19 PM »
2013 RT Plus 6M
« Reply #7 on: June 19, 2015 - 11:17:03 PM »
Buzzer switch when the key in , that looks correct
