Author Topic: emergency brake cable removal  (Read 567 times)
Offline Challenger in NC
« on: June 05, 2015 - 03:25:08 PM »
Anyone know the trick to removing this cable aside from cutting it off? I'm trying to slide the cable out through the trans cross member but it is captured on both sides.
Re: emergency brake cable removal
« Reply #1 on: June 05, 2015 - 03:28:45 PM »
There is a metal retainer that is installed into the frame rail hole to hold the cable.  You should be able to tap on the cable and push it back through the frame.
« Reply #2 on: June 05, 2015 - 03:41:36 PM »
Thanks. It did take a lot of persuation with a hammer and flatblade but it finallly let go.
