Author Topic: Cooling info please.  (Read 5706 times)
Offline gafletch
Re: Cooling info please.
« Reply #15 on: June 08, 2015 - 08:02:33 PM »
I'll check the timing, go with a 25/75 water/coolant mix and look for a better air cleaner assembly. Thanks.
« Reply #16 on: June 08, 2015 - 08:53:23 PM »
75% water and 25% coolant.  :2cents:
Water transfers heat better than prestone etc, the coolant is for freezing and corrosion.
Offline Strawdawg
    • Vortex Buicks
« Reply #17 on: June 08, 2015 - 08:56:14 PM »
yes!
Offline 734406pk
  • Andy
« Reply #18 on: June 08, 2015 - 10:54:29 PM »
You may want to try 66% water and 33% antifreeze mix. It will give you -17 deg F and a good heat transfer. Is the aluminum radiator bare or has it been painted?
« Reply #19 on: June 08, 2015 - 11:25:40 PM »
I do not see the coolant mix solving your problem + with too much water in there it may freeze & kill the block , less than 60% in an unheated garage was likely t freeze & split the block in AB
Offline gafletch
« Reply #20 on: June 09, 2015 - 08:46:55 AM »
Unpainted radiator. May move the trans cooler forward from off the radiator too. 60 water/40 coolant mix. I'm getting there!
Offline 734406pk
  • Andy
« Reply #21 on: June 09, 2015 - 09:39:57 PM »
Distilled water would be best. Using less antifreeze and more water will decrease the specific gravity (density) of the mix and increase its heat transfer capability. But on the downside as CP points out, you lose freeze protection and lowers the boiling point, so be certain to adjust the mix for the season or drain completely for storage. Better to be safe here. The aluminum cylinder heads transfer more combustion heat into the coolant than the cast iron factory heads did, so there is more heat load into the cooling system that must be transferred to the air via the radiator. Therefore the radiator will need as much help with airflow as possible. Also proper coolant circulation is important. Pulley ratios, water pump impeller clearence etc. should be checked as posted earlier. I had a customer a few years ago that had a similar over heat problem. It turned out that he painted the aluminum radiator so well it insulated it enough and ran hot at low speed. Good luck in finding the cure!
Offline cudabob496
« Reply #22 on: June 10, 2015 - 12:29:00 AM »
you also lose corrosion protection
2011 Kawasaki Z1000
