Author Topic: Frame repair  (Read 19707 times)
Offline Challenger in NC
Frame repair
« on: June 05, 2015 - 07:39:43 PM »
I need to do two things shown in this photo:
1) Cut out the bottom portion of the frame where you see the two holes. At some point, the bottom of the frame got dented up and is real wavy, the sides of the frame are straight. The area is too confined and heavy to pound out or press back into shape. I bought some flat stock, cut it to length and drilled two identical holes. Since the car is on a rotisserie, and I plan to cut this long, narrow section out, is it too risky to do without welding in a brace to stiffen this portion of the frame temporarily? I'm wondering if the weight of the car will want to buckle the frame while I'm patching it. Thought about stitching in a small section of angle from trans x-member to the front portion of the frame. Is this overkill or is there a better way to repair the frame? Some might try to heat it and beat it, but I don't think it would look right. Suggestions?
2) I also need to replace the connecting plate between frame and rocker (one with hole in corner). Does anyone reproduce this piece or know where to get a non-dented original?
Offline 74BlueFish
Re: Frame repair
« Reply #1 on: June 05, 2015 - 07:44:45 PM »
I think it's OK to cut  out and patch without any temp reinforcements.  The frame still has 3 sides of the box section to keep it's strength.
Dan
Re: Frame repair
« Reply #2 on: June 05, 2015 - 08:22:04 PM »
is it thin from rust? or just dented?
Re: Frame repair
« Reply #3 on: June 05, 2015 - 08:42:49 PM »
Just dented
Re: Frame repair
« Reply #4 on: June 05, 2015 - 08:49:12 PM »
You can't hammer it back out from the other side?
Re: Frame repair
« Reply #5 on: June 05, 2015 - 08:56:18 PM »
I could probably get some of it out, but I don't think I could make it look straight again to the point it doesn't looked damaged. You wouldn't notice unless it's on a lift, but its always bothered me.
Re: Frame repair
« Reply #6 on: June 05, 2015 - 08:57:04 PM »
If the floor was still welded to the top, it would have three sides, but if I remove the bottom section and since the floor pan is cut out, it's really two sides. Although the two sides are angles with a short leg. There are two concentric holes, one on each side of the frame section. I thought about putting a large bolt through it with a nut on each side to stiffen up the sides. I need to make this repair on the area shown in the photo plus two shorter sections in the rear frame.
Offline jimynick
Re: Frame repair
« Reply #7 on: June 05, 2015 - 10:35:42 PM »
Just cut off the top floor section covering the rail and using a flat faced bar- think old chunk of a torsion bar and a BFH- knock the dents down and out. It's easy to do and using a good sized flat faced hammer with the bar, dolly out the dings until it's flat. Easy peasy. Welding a cover is WAY too much work comparatively.  :cheers:
Re: Frame repair
« Reply #8 on: June 05, 2015 - 11:07:09 PM »
Guess I can give it a shot before resorting to the more drastic approach.
Re: Frame repair
« Reply #9 on: June 06, 2015 - 05:35:01 AM »
 :iagree: looking at your picture I can see daylight thru the hole so I thought it was already exposed.
Offline JayBee
Re: Frame repair
« Reply #10 on: June 06, 2015 - 07:22:52 AM »
Question 2), that connecting plate with the hole is a torque box. There's several suppliers on ebay.
http://www.ebay.com/itm/1970-71-CHALLENGER-CUDA-AAR-R-T-T-A-FRONT-TORQUE-BOXES-/261574171099?hash=item3ce70919db&vxp=mtr
Lots of people shop with Dave at Roseville, he gives discounts and may even carry these.
John
1970 Barracuda convertible
2014 Toyota Avalon
Re: Frame repair
« Reply #11 on: June 06, 2015 - 07:52:29 AM »
Thanks.
Offline 74BlueFish
Re: Frame repair
« Reply #12 on: June 06, 2015 - 08:21:08 AM »
Oh yea,  I see now the floor removed and only 2 sides.    I still think its OK to cut out without anything shifting.   The rocker box will keep everything aligned.  But if you're still uncomfortable weld a temp plate to where the floor would attach or some kind of rod or plate between the two ends. Good luck.
Dan
Re: Frame repair
« Reply #13 on: June 06, 2015 - 08:22:34 AM »
Thanks!
