Author Topic: Are 70 Cuda headliners the same physical size as ones in a 74?...  (Read 972 times)
Offline bs549
...I know there's a difference in the number of bows between the years, but the question is, is a 70 Cuda headliner physically the same size/dimensions:clueless:
Reason I ask...I have a new 70 headliner I've never used, and need to save some bucks by using in my 74 Cuda.
Thanks in advance...
Offline anlauto
Re: Are 70 Cuda headliners the same physical size as ones in a 74?...
« Reply #1 on: June 06, 2015 - 12:05:04 PM »
YES..of course they are. The location of some of the bows may be the same as well...
Offline bs549
« Reply #2 on: June 06, 2015 - 03:49:09 PM »
Thanks...was not so obvious to me as I had seen different part numbers for different years in aftermarket parts catalogs. ..
« Reply #3 on: June 16, 2015 - 10:44:38 AM »
the roof panel was never changed so yes it has to be the same size although the bows are different
« Reply #4 on: June 16, 2015 - 11:33:18 AM »
I think the bows attach to the roof differently in the later years.  I don't know if that will cause any problems or not.  You might have to use 1970 bows.  It might be more expensive to get the bows then it is for a new headliner.  Aren't perforated headliners only like $40?  You don't have to spend big bucks on the correct 74 headliner.
Offline bs549
« Reply #5 on: June 16, 2015 - 05:49:09 PM »
I think you're right on the different 'type' of bows (not just the number of bows).
From what I think I'm finding out, the 70-71 5 bows had to use clips for the bows (the ends of the bows are straight and fit into the pockets of the clips),
 whereas on 4 bow 71-74 (my 74). the ends of the bows have a bend which fit into predrilled holes?
On my 74, I do have 5 sets of 'holes' for bows (not sure the straight end bows would stay in place), but no place I can see to mount the clips...(i've attached pics of my 74)
All headliners I'm finding are around $80 and up, so if you have a $40 source, let me know. thks
So back to square one, as I have a 70 headliner that I don't think I can fit into my 74 which has no headliner or bows today....  :dunno:
Offline bs549
« Reply #6 on: June 16, 2015 - 10:05:37 PM »
Maybe I could use a 4 bow set in the 5 bow headliner and skip the center one? ?
