Author Topic: Pro Trans built 904 - To 750 HP  (Read 878 times)
Offline Mopar Thunder
« on: June 06, 2015 - 11:28:11 AM »
 Pro Trans 904 Reverse Valve Body 3 speed Tranny for sale, deep pan, alum direct drum w/ big piston - multi spring, alum forward drum, 245 gear set, steel carrier w/ roller thrust bearings, roller output support and reverse drum, 8 inch 4200 stall Transmission Specialties torque converter - refreshed last fall no time on it.  There was no speedometer in the car when I got it so there input area is blocked.  You will need to buy the components for a speedometer. I have upgraded my engine so I went to a built 727.  It was in the car when I got it so I don't know much more than this. Never had an issue with it. Also included is a CSR (p\n 838) Super shield
Asking $1,300 and can bring it to Carlisle when I come.
« Last Edit: June 30, 2015 - 06:40:49 PM by Mopar Thunder »
Re: Pro Trans built 904 - To 750 HP
« Reply #1 on: July 01, 2015 - 08:18:30 AM »
I added the CSR Super shield since it fits that tranny. Let me know if anyone has any questions.
