Author Topic: 4 speed shift rods  (Read 565 times)
Offline steve g
4 speed shift rods
« on: June 06, 2015 - 11:23:24 PM »
Are the 70-71 and 72-73 shift rods interchangeable? I did read somewhere the later style might interfere with aftermarket exhaust, but is there any reason a set of 72-73 rods would not work with a 70-71 setup?
Offline dfrazz
  • 1970 Cuda - 1968 Charger
Re: 4 speed shift rods
« Reply #1 on: June 07, 2015 - 09:53:29 AM »
 :popcorn: :popcorn: :popcorn:
« Reply #2 on: June 07, 2015 - 11:18:30 AM »
Only the reverse rod is an issue , the 70 angles forward , the later one do a large loop rearward & could interfere with the H pipe if you have one
« Reply #3 on: June 07, 2015 - 12:30:43 PM »
I have the later type and it doesn't interfere with the H pipe.
