Author Topic: Capped or Uncapped?  (Read 2250 times)
Offline FY1Cuda
Capped or Uncapped?
« on: June 07, 2015 - 02:52:48 PM »
There's a very small tube sticking out under the choke housing on our Holley 4150.  What is it, and do we cap it or leave it open?
Offline HP_Cuda
  • Mopar or No Car!
Re: Capped or Uncapped?
« Reply #1 on: June 07, 2015 - 03:47:04 PM »
Cap it or you will have a vacuum leak, it looks like it's another external fitting for things like a vacuum line to the distrib.
Btw, what carb is that?
Offline roadman5312
« Reply #2 on: June 07, 2015 - 04:27:38 PM »
I believe its a vacuum line for choke pull off.  Vacuum advance is above it.
Offline FY1Cuda
« Reply #3 on: June 07, 2015 - 04:50:35 PM »
Thanks. It's a Street Avenger 870.  I'll cap it.
Offline roadman5312
« Reply #4 on: June 07, 2015 - 05:01:35 PM »
[/quote
 Run a vacuum hose from it to the small tube under the front bowl. It operates the piston inside the choke housing.
Offline HP_Cuda
  • Mopar or No Car!
« Reply #5 on: June 08, 2015 - 03:31:49 AM »
Unless you don't care about the choke, then just cap it.
 :2thumbs:
Offline FY1Cuda
« Reply #6 on: June 08, 2015 - 11:17:07 AM »
I'm no carb expert, but the choke is electric and has a coil inside that expands when given voltage, and that's what moves the choke.  I don't think there's any piston there.
Offline Fred
« Reply #7 on: June 08, 2015 - 12:05:09 PM »
Sorry for the hijack, but I have a new Holley with electric choke and that same red plastic piece behind it.  It often sticks and keeps engine idle too high.  I can move it with my finger and it unsticks to let engine slow down.  It will not move on its own, once stuck.  Am I missing something?
Offline roadman5312
« Reply #8 on: June 08, 2015 - 12:20:20 PM »
This is how it should be hooked up, the T can be eliminated.
Offline roadman5312
« Reply #9 on: June 08, 2015 - 12:26:27 PM »
The lever at top connected to rod that is connected to the piston. Vacuum pulls on the piston, causing choke pull off. It slightly opens the choke when engine starts.
Offline HP_Cuda
  • Mopar or No Car!
« Reply #10 on: June 08, 2015 - 02:47:06 PM »
That's a somewhat crazy design, so unless the car is idling the choke will go off.
I guess that will get around the waiting until the coil heats up via electricity trick, hence why many folks just disconnect them.
As for the red plastic piece, you can look here on how to setup your standard electric choke:
https://www.youtube.com/watch?v=0H5IBSFgYJE
Offline FY1Cuda
« Reply #11 on: June 09, 2015 - 04:44:31 PM »
Thanks, Roadman.  I didn't know there was a piston in there too.  It seems strange to me that the plumbing on the carb is such a mystery. I'd think that Holley would make it clear what you do with all the ports that come off it.  If those two are meant to be connected, why are they different diameters do you suppose?
Offline roadman5312
« Reply #12 on: June 09, 2015 - 05:04:18 PM »
Different diameters not sure. The port that comes from under the bowl is full manifold vacuum, so the unused end of the T can be used for trans vacuum modulator or vacuum to A/C controls. If not needed just cap off. Not for the vacuum advance,  :nono:, that is the tube above the idle mixture screw. Vacuum going to the piston will also influence how the fast idle cam operates. It can be very time consuming and frustrating to get the choke set just right so the motor fires right up.
