Author Topic: 70 challenger hood latch  (Read 657 times)
Offline rrod
« on: June 08, 2015 - 12:43:15 AM »
is the hood safety latch mechanism for a 70 challenger in reproduction or do anyone restore them?  Also I need a attach stud which attaches the hood latch bracket to the radiator cowl support. Mine broke when I was removing the bracket. Are they available from a vendor?  They are the two upper studs which go through the radiator cowl support and the hood mechanism latch bracket.
Offline AARTA340
Re: 70 challenger hood latch
« Reply #1 on: June 08, 2015 - 04:17:21 AM »
Post in parts wanted and I bet you will get someone who has an extra at a fair price. :)
Offline anlauto
« Reply #2 on: June 08, 2015 - 06:37:39 AM »
Stephan Fournier in Quebec restores latches better then new :2thumbs:
The stud is an easy fix...drill out the center, tap new threads through it, screw in a new bolt to the correct lenght, cut it off and weld it on the back side.
