Author Topic: 1970 FM3 Challenger Project  (Read 16704 times)
Offline YellowThumper
  • I left the snow for this?
Re: 1970 FM3 Challenger Project
« Reply #45 on: July 15, 2016 - 04:41:57 PM »
Nothing says muscle car more than FM3
Offline manycj
« Reply #46 on: July 18, 2016 - 08:02:40 AM »
Here it is after sanding and buffing.  I sanded it down using 3m Trizact disks (1500 then 3000 then 5000) before buffing. It only took one buffing with Perfect-it 3 to finish it up.
Know I need to do the black out of the radiator support, windshield opening and rocker pinch welds. Followed by the vinyl top install.
Chris
Offline Rolling_Thunder
  • only 2 things get my attention, gas and perfume
« Reply #47 on: July 18, 2016 - 08:34:55 AM »
amazing looking car -  great job!    SS or a BC/CC ?
2013 Dodge Challenger R/T - 5.7L / 6-speed
1973 Dodge Challenger Rallye - 340 / Auto
1968 Dodge Charger - 6.1L / 6-speed
1964 Dodge Polara - 440 8-71 / 4-speed
Offline manycj
« Reply #48 on: July 18, 2016 - 08:43:40 AM »
BC/CC.  PPG DBC 2260 Basecoat and PPG DCU 2002 Concept Clear.
The color appears to be dead-on when compared to existing color from the car and from the giant paint chip in the 1970 Trim Book insert:
http://www.pantherpink.com/docs_fm3_fj6_1.htm
Offline larry4406
« Reply #49 on: July 19, 2016 - 06:18:10 AM »
Very nice!  Can you provide some details of your paint booth or fan setup?  I assume you are painting this in your garage?
Offline manycj
« Reply #50 on: July 19, 2016 - 07:47:01 AM »
I did paint it in my garage.  Immediately to the right of the car is a window. I installed a square fan in the window with a furnace filter to fill in the gap above the window.  Way to the left side of the car, where I painted the hood, trunk lid and valances, I have an overhead door. I opened the door enough to place 2 more square fans and used furnace filters to fill the voids. The garage floor was hosed down the night before. Also I painted during the day so that bugs are not attracted to the light and then commit suicide in the clearcoat.
Offline 340challconvert
  • A66- Challenger Registry
    • A66CHALLENGER.COM
« Reply #51 on: July 20, 2016 - 09:15:36 PM »
Outstanding Job
1970 Challenger A66 Registry
Offline manycj
« Reply #52 on: July 27, 2016 - 02:17:39 PM »
Here are some pictures after the blackout process. This car did not have its upper cowl blacked out.  The factory only brushed on black paint (perhaps black windshield primer ?) on the bottom edge of the windshield opening and the windshield pillars. Next up: Vinyl Top installation. -Chris
« Reply #53 on: July 28, 2016 - 09:04:30 AM »
 :2thumbs:
Offline blown motor
« Reply #54 on: July 28, 2016 - 09:10:23 AM »
Wow that's pink! Can't wait to see it done.
Offline manycj
« Reply #55 on: August 08, 2016 - 08:25:44 AM »
I finally got a chance to install the vinyl top this weekend. How did I do for my first vinyl top install ?
Chris
Offline blown motor
« Reply #56 on: August 08, 2016 - 08:51:14 AM »
It's...  :'(  :'( ...beautiful!
« Last Edit: August 08, 2016 - 08:53:30 AM by blown motor »
Offline loco340cuda
« Reply #57 on: August 08, 2016 - 09:10:21 AM »
That looks great!
1970 Cuda 340 4-speed - now stroked to 416ci (SOLD)
2017 Mustang Shelby GT350
Offline manycj
« Reply #58 on: August 08, 2016 - 01:23:23 PM »
I really didn't find any Challenger specific tips on the web, but I did come across some useful info.  Putting strips of wood in the window opening helps with locating the top fore/aft and it also helps when gluing the rear down. Also, once you have the first half of the roof glued down (from center to outboard seam), pull the vinyl back and glue the rear at the bottom of the rear window on the side you are working on. Then glue the section on the quarter and work your way to the front. Then you can go to the opposite side and finish the center of the roof. When you glue down the center start near the rear and pull tight so that there is no slack at the bottom of the rear window. This will ensure that the fit is good below the window.  I've been seeing cars at the shows were the tops weren't installed right and the installer had to shorten the section below the window. -Chris
    • A66CHALLENGER.COM
« Reply #59 on: August 20, 2016 - 09:31:15 AM »
Really appreciate you sharing the progress of your Challenger project.
Pictures of your progress are great.
