Author Topic: Tremic question.  (Read 1765 times)
Offline rmsolimando
Tremic question.
« on: June 11, 2015 - 11:57:19 AM »
Hello all
I recently converted an auto challenger over to a 5 speed tremic from hurst. Everything seems great except the trans is leaking fuild out of here the shift rod enters the trans. (Right above the Drive shaft) There is a small rubber bushing that seals the end. Does any one know where i can a replacement? I Have put in a few calls to hurst already, ive been paying phone tag with the tech dept.
Thanks Rob
Offline DocMel
Re: Tremic question.
« Reply #1 on: June 11, 2015 - 12:14:30 PM »
Go to ANY vendor that sells tremecs:  They will hook you up.   Even Keisler  ::)
Offline rmsolimando
« Reply #2 on: June 11, 2015 - 03:00:29 PM »
thanks for the info, the hurst tech line called me back and just sent me one.
Offline bigblue73
« Reply #3 on: June 15, 2015 - 04:36:50 PM »
Just to add in hear - Please check your fluid level.  It sounds like you may have a little to much.  2 3/4 quarts is all it takes.
By the way the seal number is  Hercules Hydraulics # MO5-15 x 24 x 7 TC
Offline roadman5312
« Reply #4 on: June 15, 2015 - 04:42:25 PM »
                      Thats what I was thinking, thats way higher than the level of the fill plug. Should never be fluid up there.   :dunno:
Offline bigblue73
« Reply #5 on: June 15, 2015 - 08:06:00 PM »
You are correct.  That seal is designed to run wet or dry.  I've never heard of a failure.
« Reply #6 on: June 15, 2015 - 08:06:29 PM »
Keisler had a bad habit of machining through that area so you may have a hole in the housing too
Offline roadman5312
« Reply #7 on: June 16, 2015 - 07:04:02 AM »
           Thats not the only bad habit Keisler had.    :stomp:  Glad their gone.
« Reply #8 on: June 16, 2015 - 08:01:14 AM »
Offline rmsolimando
« Reply #9 on: June 20, 2015 - 09:25:40 PM »
Thanks Guys i will double check the level just to make sure. The new seal did stop it from leaking though
