Author Topic: Need help with gas gauge sender -ohm's readings  (Read 1587 times)
« on: June 11, 2015 - 06:51:29 PM »
I'm installing speedhut gauges and need to know the ohms the sender is calibrated for?
My options are
240 ohms Empty and 33 ohms Full
=( 240/33)
70/10
0/30
0/90
10/180
90/0
16/158
My other option is to empty the tank calibrate , then fill the tank and calibrate , problem is I don't have enough gas cans to store the fuel while I'm calibrating.
Thanks!  :wave:
Re: Need help with gas gauge sender -ohm's readings
« Reply #1 on: June 11, 2015 - 07:53:59 PM »
70/10 will work for you.
 :cheers:
« Reply #2 on: June 11, 2015 - 09:05:49 PM »
 :cheers:
AWESOME!!!1  :worshippy :2thumbs:
Offline Katfish
  • 70 Challenger
« Reply #3 on: June 11, 2015 - 10:55:33 PM »
Agreed
« Reply #4 on: June 11, 2015 - 11:12:30 PM »
Thanks guys, yep it worked says I have 3/4 of a tank same as the old gauge!  :2thumbs:
« Reply #5 on: June 13, 2015 - 07:54:03 AM »
Post up a pic of your new gauge set-up after you're done.   :picture:
Did you go with the gps speedo as well?
« Reply #6 on: June 13, 2015 - 07:55:10 AM »
I will, yes GPS speedo too. I'm having an issue with the oil pressure gauge not working.
