Author Topic: Dash lights and wiper/washer problem  (Read 1460 times)
Offline 55gasser
  • V-code
« on: June 12, 2015 - 01:36:39 AM »
Seems like I lost both wiper/washer and all dash lights at the same time in my 71 Cuda. Couldn't find any fuses for these... What am I missing here? Is there a circuit somehere that can be broken?
Appreciate feedback!
Norway
BS23V1*****
Offline Denison636
Re: Dash lights and wiper/washer problem
« Reply #1 on: June 12, 2015 - 05:37:12 AM »
Check all your switches.  Had this happen to me and had a bad switch. I checked all components and ran them with 12volt at the plug in. Just take your time there and be sure what is hot to turn stuff when you check.
Its just a little 340 with a miss
Offline 55gasser
  • V-code
« Reply #2 on: June 12, 2015 - 07:24:23 AM »
I have no power in to the swich after testing. Is there a separate fuse somewhere...that I don't see?
Norway
BS23V1*****
Offline HP_Cuda
  • Mopar or No Car!
« Reply #3 on: June 12, 2015 - 10:31:14 AM »
Dash lights and your wiper setup are seperate.
So check your orange connection under your dash as it probably came unplugged. Or your ground for the dash lights is poor.
Where the wiper connection occurs I would suspect that the switch failed and you need to replace it. Fairly easy to do.
« Reply #4 on: June 12, 2015 - 10:53:02 AM »
I was thinking ground.. both need to be grounded but you should still read power to the switches
« Reply #5 on: June 12, 2015 - 11:40:19 AM »
 You need a good ground for the dash so both will work
Offline 55gasser
  • V-code
« Reply #6 on: June 12, 2015 - 11:42:00 AM »
Absolutely no power coming in to the swiches. I was hoping to find a broken fuse...but not yet.  :banghead: Will re-check the ground!
Norway
BS23V1*****
Offline TelisSE440
« Reply #7 on: June 12, 2015 - 05:00:37 PM »
Check that you have current in both sides of the fuse in every fuse slot in the box.
