Author Topic: Clutch doesnt seem to disengage  (Read 5315 times)
Offline HP_Cuda
  • Mopar or No Car!
Re: Clutch doesnt seem to disengage
« Reply #15 on: June 18, 2015 - 12:44:49 PM »
By chance, did you take an auto setup and convert it over to 4speed?
Then you might have mega issues with the throwout bearing and basically you have stuffed the input shaft into too narrow a hole in the crank.
Just something to look out for based on what you have said.
B
Offline Bluemonster71RT
« Reply #16 on: June 18, 2015 - 05:22:23 PM »
B
No. The car was born a 4 speed :)
1971 Challenger RT 383 4spd
Offline HP_Cuda
  • Mopar or No Car!
« Reply #17 on: June 18, 2015 - 06:11:37 PM »
Probably not enough throw. Can you measure how much you have now from the top and fully depressed?
« Reply #18 on: June 18, 2015 - 09:42:46 PM »
It's just enough now but I know that was that was/is the problem. The fork angle is to far back. If it were a 1/2' more forward I don't think this conversation would exist.
Offline 73EStroker
« Reply #19 on: June 19, 2015 - 11:01:10 AM »
And another possible sign is - does your clutch pedal bottom out before it is near the floor? Also be careful of trying to get more travel as you will drive the TO bearing mechanism into rotating parts due to over travel.
I know all these things because I have suffered through this and always hoped the issue was on the outside when it was in the difficult to get at inside! Now I have zero clutch issues just traction problems
Barry (Salmon Arm)
« Reply #20 on: June 19, 2015 - 11:49:13 AM »
The pedal was just about the end of travel before when the fork was hitting the bell. The pedal is now down all the way and pulling the fork and reinstalling it. I'd say that had I not ground off the bell, there would be about a 1/16" of space.  The only thing I don't know is if it was that way 15 years ago when the shop originally installed the bell. The car worked so I never inspected it.
