Author Topic: Engine oil for 440 '70  (Read 2370 times)
Offline YuryP
« on: June 13, 2015 - 05:26:40 AM »
Hi everybody!
What do u think what kind of engine oil is the best for 440 1970, I'm driving the car summer only.
Thanks beforehand!
Re: Engine oil for 440 '70
« Reply #1 on: June 13, 2015 - 08:10:37 AM »
Joe Gibbs or Brad Penn
Offline roadman5312
« Reply #2 on: June 13, 2015 - 08:17:24 AM »
Or Valvoline VR1.  If your running flat tappet cam you need zinc.
Offline stinger
« Reply #3 on: June 13, 2015 - 09:37:46 AM »
I run Brad Penn 10w30 with 40 psi @ 850 rpm hot.
Offline cudabob496
« Reply #4 on: June 13, 2015 - 10:44:21 AM »
I use Mobile 1 fully synthetic 5W-30
2011 Kawasaki Z1000
Offline bc3j
« Reply #5 on: June 13, 2015 - 12:47:24 PM »
Joe Gibbs HR 10W30 conventional oil.
Offline YuryP
« Reply #6 on: June 13, 2015 - 05:01:15 PM »
Everybody thanks a lot!
If I understand correctly mineral oil is better than synthetic?
« Reply #7 on: June 13, 2015 - 07:32:36 PM »
no , synthetic is better but it has to have enough ZDDP content if you are using a flat tappet cam .
With a full roller cam system other oils will work
Offline cudabob496
« Reply #8 on: June 13, 2015 - 09:14:29 PM »
synthetic is superior
2011 Kawasaki Z1000
« Reply #9 on: June 13, 2015 - 10:11:39 PM »
Mobil 1 15W50 has the high ZDDP, and Castrol Edge Syntec 5W50 (marked on the label Specially formulated for Classic Cars) as well. Both full synthetic oils. Also have some VR1 Valvoline Dino Oil on hand too.
Sometimes that's all I can find where I live.
« Last Edit: June 13, 2015 - 10:16:03 PM by 1970 RT Challenger 1970 »
Offline YuryP
« Reply #10 on: June 17, 2015 - 01:07:10 PM »
Thanks guys!
i've taken Mobil 15w50
