Author Topic: anyone else get a strange hard to describe noise from your engine?  (Read 1072 times)
Offline stinger
mine sounds fine when first started then a min or so later I get this low tone from the carb that sounds like a French horn playing one note until the engine is fully warmed up then it goes away. 3 different carbs and dose it like clockwork,hard to figure out . it's a faint sound coming from the carb/manifold and starting to bug me. :clueless:
Offline cudabob496
Re: anyone else get a strange hard to describe noise from your engine?
« Reply #1 on: June 13, 2015 - 10:43:12 AM »
vacuum leak?
2011 Kawasaki Z1000
Offline stinger
« Reply #2 on: June 13, 2015 - 11:06:30 AM »
if it is its in the carb throat cause that's where it's coming from
Offline stinger
« Reply #3 on: June 13, 2015 - 04:55:08 PM »
car was surging at cruise 3000 rpm so I caped off the vac advance. fixed the surging and no more noise. I'm such a novice
Offline blown motor
« Reply #4 on: June 13, 2015 - 05:34:56 PM »
But you're learning and that's cool.
Offline cudabob496
« Reply #5 on: June 13, 2015 - 07:10:35 PM »
natural mechanical genius!
2011 Kawasaki Z1000
« Reply #6 on: June 13, 2015 - 07:29:48 PM »
 :2thumbs:
