Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Off Topic
Tools And Equipment
(Moderators:
69ChargerRT
Chryco Psycho
4Cruizn
Oldschool
steering input shaft tool
« previous
next »
Print
Pages: [
1
Author
Topic: steering input shaft tool (Read 2023 times)
mopar jack
Full Member
on:
June 13, 2015 - 09:59:55 PM »
Need to replace the seal in my steering box at the input shaft. Chrysler had tool c-3638 that could pull the seal without pulling the box out of the car. Where can find one?
Logged
burdar
Sr. Resident
Re: steering input shaft tool
Reply #1 on:
June 15, 2015 - 12:47:00 PM »
Just drill a small hole in the seal. Then run a screw into the hole. You'll be able to pull out the seal. I replaced mine with the box in the car.
Logged
mopar jack
Full Member
Reply #2 on:
June 15, 2015 - 01:45:38 PM »
Thanks I tried the screw trick yesterday and it didn't work so I took a awl and put it between the shaft and seal and popped it out. New seal works great.
Logged
HP_Cuda
Hit the skinny little pedal on the right!
Sr. Resident
Mopar or No Car!
Reply #3 on:
June 15, 2015 - 02:38:55 PM »
Isn't there like 3-4 seals inside the box?
Logged
mopar jack
Full Member
Reply #4 on:
June 15, 2015 - 03:15:09 PM »
Yes. There are a couple of O rings if you pull the worm gear but not needed if just replacing shaft seal in place.
Logged
HP_Cuda
Sr. Resident
Mopar or No Car!
Reply #5 on:
June 15, 2015 - 05:06:27 PM »
Might just pull mine and redo the entire thing.
My luck is to pull the shaft seal and replace it and still have leakage or something else happens.
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Off Topic
Tools And Equipment
(Moderators:
69ChargerRT
Chryco Psycho
4Cruizn
Oldschool
