It should be cheap to pick up a steel crank with all the strokers being built or build a stroker yourself .
With a 4 spd I would avoid the cast crank anyway , the cast crank is external balance & you would need to balance the whole assy , crank rods pistons damper & flywheel or add weight to internally balance it
