G3 Hemi, 545RFE in '70 E body
Author Topic: G3 Hemi, 545RFE in '70 E body  (Read 2609 times)
Offline 3D
« on: June 15, 2015 - 03:15:33 PM »
O.K Gurus, need some questions answered.....If possible,
1) When installing motor and trans, what height/angle should the tail shaft/output shaft be at? I need to cut out the tunnel and only want to do it once.
2) What are you guys using for the speed sensor on the 545RFE?
3) With a leaf spring suspension what should the axle pinion angle be?
Any other info would be appreciated.
Offline 3D
Re: G3 Hemi, 545RFE in '70 E body
« Reply #1 on: June 16, 2015 - 10:36:01 PM »
O.K, Found this over on Moparts, answers #1 & #3 of my questions.
http://www.moparts.org/Tech/Archive/axle/8.html
Offline thedodgeboys
  • ''Normal’s Overrated''
    • THE DODGE BOYS
« Reply #2 on: June 22, 2015 - 10:13:07 PM »
#2 you can use a gps speedo or converter box or magnets on the drive shaft.
Go Fast & Have Fun...
