Author Topic: Intake gasket - 440  (Read 1311 times)
Intake gasket - 440
« on: June 15, 2015 - 11:31:08 PM »
I have the fel-pro intake gaskets with pan. The instructions say to attach all the gaskets to the metal pan prior to installation and to let it dry thoroughly. Use fast acting adhesive. That's all the description they give. What kind of adhesive would you use for that?
Pretty sure I put them together dry 15 years ago?
Re: Intake gasket - 440
« Reply #1 on: June 15, 2015 - 11:40:03 PM »
I use the paper gaskets between the heads & pan only , an anerobic sealer is best as fuel eats silicone , then just seat the intake on the pan .  I doubt you will get the bolts started with all 4 gaskets in there
Offline cudabob496
« Reply #2 on: June 16, 2015 - 01:11:55 AM »
i used paper gasket above and below pan, but had to enlagre one side
of the bolt holes in the intake  slightly.  Holding fine for 15 years.
2011 Kawasaki Z1000
« Reply #3 on: June 16, 2015 - 01:18:57 PM »
OK. But how come?
Offline cudabob496
« Reply #4 on: June 16, 2015 - 04:54:45 PM »
so you get a better, more long lasting seal!
2011 Kawasaki Z1000
Offline HP_Cuda
  • Mopar or No Car!
« Reply #5 on: June 16, 2015 - 05:28:29 PM »
Apparently oil leaks are common at the front and rear of the intake where the valley pan hold downs are.
RTV black is what I will use.
OK. But how come?
Offline cudabob496
« Reply #6 on: June 16, 2015 - 06:31:48 PM »
ya, in the corners, so just use a little more RTV there. But no RTV for the intake gasket.
2011 Kawasaki Z1000
