The passenger side hose doesn't have the 10-12" long formed metal tube at the compressor end... The drivers side hose (high pressure) is actually longer on a small block than a big block hose... The metal ends are exactly the same, just the hose length is different... And the formed metal liquid line crosses from a connection on the drivers side of the condenser across the hood latch area to the passenger fender where it bends back toward the fire wall & attaches to the receiver dryer... A 70 vintage liquid line attached to the condenser on the passenger side so it's probably 2 feet shorter than the line you have.... It all works but it's not correct.... Photo shows a correct big block suction line..
