Slow progress but productive. I pulled out the headlight buckets and repaired the rusted through areas and plug welded them back in. After I painted the back of the fenders with POR15 I sprayed the fenders with sealer/primer. I still need to do the filling and sanding to get them ready for mounting but it was a lot of work to get them to this stage. I also noticed some differences between the two and I think the passenger side is a newer fender. I found damage from a wreck on the cowl where the inner fender had been jammed into it. The frame is okay so on I go. I also repaired a break on the piece on the drivers side. This must be different as well as there was no damage to the fender. I primed that as well. Next up is the doors. They are in good shape, so I hope, and I will POR15 the inner areas especially around the bottom and weep holes.
