Author Topic: Does anyone know what this is?  (Read 1871 times)
Offline Simple
« on: June 16, 2015 - 08:57:35 PM »
I bought a 70 Cuda and this was laying in the floor when I got it. Anybody know what it is or what it is for?
Offline BS CUDA
Re: Does anyone know what this is?
« Reply #1 on: June 16, 2015 - 09:03:54 PM »
Neutral safety switch
Offline anlauto
« Reply #2 on: June 16, 2015 - 09:11:28 PM »
..for an automatic
Offline Simple
« Reply #3 on: June 17, 2015 - 06:35:57 AM »
Thanks guys!
Offline Simple
« Reply #4 on: June 17, 2015 - 06:48:05 AM »
Next question...do I HAVE to have it on the Cuda?
Offline anlauto
« Reply #5 on: June 17, 2015 - 07:16:11 AM »
If it's not there, your transmission will leak all of it fluid first off. If it's not wired to your starter relay, your car will not start.
Offline Simple
« Reply #6 on: June 17, 2015 - 12:09:24 PM »
If it's not there, your transmission will leak all of it fluid first off. If it's not wired to your starter relay, your car will not start.)
Ok, got it, thanks!  Have you ever heard of some type wire (I'm assuming on the transmission) that prevents the car from going into gear? Or guess I should say prevents it from driving? Because it goes into gear but will just set there. Someone said its a wire on the tranny????
Offline dfrazz
  • 1970 Cuda - 1968 Charger
« Reply #7 on: June 17, 2015 - 12:10:50 PM »
The plug to the NSS controls when your reverse light are on too.
« Reply #8 on: June 17, 2015 - 01:14:41 PM »
The NSS only allows the car to be started in PARK or NEUTRAL.  The starter won't engage if the car is in any other gear.  The NSS also turns on the reverse lights when the shifter is put into reverse.
There is no "wire" on the trans that would make the car not move.  There is "kickdown linkage" that goes from the carb to the trans.  That linkage increases the transmission's line pressure when you press on the gas pedal.  If the car was driven without that linkage, the trans might be hurt internally.  Check to make sure there is a NSS screwed into the trans on the drivers side.  Then, make sure the trans is full of fluid.
Offline anlauto
« Reply #9 on: June 17, 2015 - 01:24:31 PM »
 :smilielol:...that made me chuckle
« Reply #10 on: June 17, 2015 - 02:19:52 PM »
Well, if it was missing, I didn't want him dumping a bunch of fluid on his driveway.
